The topic you requested could not be found.
Related topics are listed below.
Dynamic Input
Precision tools » Precision tools » Dynamic Input
Dynamic Input Status bar: Button Hot key: F12 Dynamic input displays the command interface near the cursor in the drawing area. At the right time, current prompts, command requests, input fields, lists of selectable keywords, dimensions of edited geometry are…
Dynamic UCS
Coordinate Systems » Dynamic UCS
Dynamic UCS Status bar: Dynamic UCS Hotkeys: F6 Command line: UCSDETECTCMD When you create an object and move the cursor over a flat segment, the UCS temporarily aligns with it. This makes it possible to immediately draw in the plane of the highlighted face…
Dynamic display sizes details
Mechanica Module » Designing » Dynamic display sizes details
Status Bar
nanoCAD User Interface » Status Bar
h3. Status Bar There are interface elements in the status bar: Current coordinates of the cursor: Display modes: dynamic display of cursor absolute coordinates when the cursor is moving, display of relative distance (distance
Reset Block
Version 23 » Reset Block
Reset Block Block insert context menu: Reset block Command line: RESETBLOCK Returns the parameters of the selected dynamic block inserts to their original state, resetting the entire history of their modifications. The command is designed to restore dynamic block…
Calculation of parameters
Construction Module » construction MechWizard » Calculation of parameters
Calculation of parameters Set parameter in the dialogue Variable for which this flag is set to be available for editing of dialogue insert details. Dynamic selection Processed when the position of the cursor relative to the insertion point of the object…
Polar Array
Version 23 » Polar Array
Polar Array Ribbon: Home – Modify > Polar array Ribbon: Draw – Modify > Polar array Menu: Modify – Polar array Command line: ARRAYPOLAR Even distribution of objects’ copies in a circular array around a center point or rotation axis. Creating an…
Construction Module » dbscript » Appendix 1. A list of keywords and reserved variables
Appendix 1. A list of keywords and reserved variables SVersion=2; The first line of the script, which determines the version of the interpreter strTheType Object type strTheName Object Name strTheSubType Subtype object pntOrigin Insertion…
Path Array
Version 23 » Path Array
Path Array Ribbon: Home – Modify > Path Array Ribbon: Draw – Modify > Path Array Menu: Modify – Path Array Command line: ARRAYPATH Even distribution of objects’ copies in a circular array around a center point or rotation axis. Creating an…
Create Layer
Version 23 » Create Layer
Create Layer Ribbon: Home – Layers > Create layer Menu: Format – Layer Tools > Create Layer Toolbar: Properties – Command line: NEWLAYER The command to quickly create a layer with current properties. By opening the Properties toolbar, you can…
Standard parts library
Construction Module » work_standart_element » Standard parts library
Standard parts library Main menu: Construction – Library objects > Standard parts library. Ribbon: Construction – Library objects > Standard parts library. Toolbar: “Library objects”) > Standard parts library . Command…
Rectangular Array
Version 23 » Rectangular Array
Rectangular Array Ribbon: Home – Modify > Rectangular Array Ribbon: Draw – Modify > Rectangular Array Menu: Modify – Rectangular Array Command line: ARRAYRECT Arranged distribution of copies of objects in any combination of rows, columns, and…
Context menu entry fields
Construction Module » Basic_know » Context menu entry fields
Context menu entry fields The input fields for design elements have a context menu that allows you to insert specific values ​​or objects. Let’s look at the frequently encountered context menu commands: “History” – call the last…
Construction Module » Note » Contruction Module: Chain note
Contruction Module: Chain note Main menu: Draw – Notes > Chain note. Main menu: Construction – Notes > Chain note. Ribbon: Annotate – Leaders > Chain note. Ribbon: Construction – Symbols > Chain note. Toolbar: Notes > …
Contruction Module: Node note
Construction Module » Note » Contruction Module: Node note
Contruction Module: Node note CAD drafting Node note 0Main menu: Draw – Notes > Node note. Main menu: Construction – Notes > Node note. Ribbon: Annotate – Leaders > Node note. Ribbon: Construction – Symbols > Node note. …
Construction Module » Note » Contruction Module: Note for multilayered constructions
Contruction Module: Note for multilayered constructions Main menu: Draw – Notes > Note for multilayered constructions. Main menu: Construction – Notes > Note for multilayered constructions. Ribbon: Annotate – Leaders > Note for…
Construction Module » Note » Contruction Module: Section note
Contruction Module: Section note Main menu: Draw – Notes > Section note. Main menu: Construction – Notes > Section note. Ribbon: Annotate – Leaders > Section note. Ribbon: Construction – Symbols > Section note. Toolbar: …
Construction Module » Note » Construction Module: Comb leader note
Construction Module: Comb leader note Main menu: Draw – Notes > Comb leader note. Main menu: Construction – Notes > Comb leader note. Ribbon: Annotate – Leaders > Comb leader note. Ribbon: Construction – Symbols > Comb leader…
Construction Module » Note » Contruction Module: Mechanical note
Contruction Module: Mechanical note Main menu: Draw – Notes – Mechanical note. Ribbon: Annotate – Leaders > Mechanical note. Command line: SPNOTE, NOTE. Procedure Call the command. If the option “Show dialog before inserting…
Construction Module » Note » Contruction Module: Linear aligned note
Contruction Module: Linear aligned note Main menu: Draw – Notes > Linear Aligned note. Main menu: Construction – Notes > Linear Aligned note. Ribbon: Annotate – Leaders > Linear Aligned note. Ribbon: Construction – Symbols > …
Fixed joint
Construction Module » weld » Fixed joint
Fixed joint Main menu: Construction – Weld > Fixed joint. Ribbon: Construction – Symbols > Fixed joint. Toolbar: “Weld”> Fixed joint . Command line: SPFIX. Procedure 1. Call the command “Fixed joint”. 2.…
Lengthen Objects
Editing Objects » Commands to edit geometric object » Lengthen Objects
Lengthen Objects Commands to Edit Objects Geometry Ribbon: Home, Draw – Modify > Lengthen objects Ribbon: Home, Draw – Modify > Delta Ribbon: Home, Draw – Modufy > Dynamic Menu: Modify – Lengthen objects Toolbar:…
Construction Module » Note » Contruction Module: Construction note
Contruction Module: Construction note Main menu: Draw – Notes > Construction note. Main menu: Construction – Notes > Construction note. Ribbon: Annotate – Leaders > Construction note. Ribbon: Construction – Symbols > Construction…
Arc length dimensioning
Execution of Drawings commands » Dimensioning » Arc length dimensioning
Arc length dimensioning Ribbon: Home, Annotate – Dimensions > Arc Length Menu: Dimensions – Arc Toolbar: Utilities – Command line: MDIMARC This command creates an arc length dimension. Arc length dimensions measure the distance along an arc or…
Editing Objects » Ways to edit objects » Editing Objects Using Ordinary Grips
Editing Objects Using Ordinary Grips Grips that can change editing mode by round robin in rotation are called multifunctional. Rotation of editing modes is carried out for the active (selected) grip using the CTRL button. Multifunctional are grips that have an ability…
Editing Objects » Ways to edit objects » Editing objects using multifunctional grips
Editing objects using multifunctional grips Grips that can change editing mode by round robin in rotation are called multifunctional. Rotation of editing modes is carried out for the active (selected) grip using the CTRL button. Multifunctional are grips that have an…
Static beam calculation
Construction Module » Utilits » Static beam calculation
Static beam calculation Main menu: Construction – Utilits > Static beam calculation. Toolbar: Calculation beams (toolbar “Utilits”). Command line: SPBEAM. Library: Calculations – Loads – Beam. Library: Calculations –…
Associative Arrays
Version 23 » Associative Arrays
Associative Arrays Associativity allows you to quickly make changes in the entire array due to the established relationship between the elements, while all the elements of the associative array are perceived as a single object. In an associative array, you can change…
Text
Execution of Drawings commands » Work with Text » Text
Text Ribbon: Home, Annotate – Text > Singleline Text Menu: Draw – Text > Single-line Text Toolbar: Draw – Toolbar: Text – Command line: TEXT, DTEXT The command allows you to create one or more lines of text. Each text line is an independent…
Multiline Text
Execution of Drawings commands » Work with Text » Multiline Text
Multiline Text Ribbon: Home, Annotate – Text > Multiline Text Menu: Draw – Text > Multiline Text… Toolbar: Draw – Toolbar: Text – Command line: MT, MTEXT, MTEXTCREATE, T Multiline text consists of any number of text lines or paragraphs that…
Object Selection
Editing Objects » Selection of objects » Object Selection
Object Selection To edit objects you have to select them. There are different ways to select objects in nanoCAD. The most common way to select is to select objects with the mouse cursor without using additional commands. Objects can be selected both individually and…
Editing Objects » Selection of objects » Selection of objects
Selection of objects To edit objects you have to select them. There are different ways to select objects in nanoCAD. The most common way to select is to select objects with the mouse cursor without using additional commands. Objects can be selected both individually…
Diameter dimensioning
Execution of Drawings commands » Dimensioning » Diameter dimensioning
Diameter dimensioning Ribbon: Home, Annotate – Dimensions > Diameter Menu: Dimensions – Diameter dimension Toolbar: Utilities – Command line: MDIMDIA For dimensioning the diameter of a circle: Start the Auto command. Place the cursor over the…
Execution of Drawings commands » Dimensioning » Horizontal, vertical and aligned dimensioning
Horizontal, vertical and aligned dimensioning In the following examples, horizontal, vertical and aligned dimensions are created by using the Auto command. Ribbon: Home, Annotate – Dimensions > Linear Menu: Dimensions – Auto Toolbar: Utilities – …
Radial dimensioning
Execution of Drawings commands » Dimensioning » Radial dimensioning
Radial dimensioning Ribbon: Home, Annotate – Dimensions > Radius Menu: Dimensions – Radius dimension Toolbar: Utilities – Command line: MDIMRAD To draw the radius of a circle: Start the Auto command. Select the Radial option in the command…
new 9
Construction Module » FormEdit » new 9
new 9 Input field. The input field is used to enter numeric or symbolic expressions for further processing. Properties command: View Visible 1 Alignment On the edge Multiline 2 Flat 3 Tip Linking (None) Enable 4 Text None Formatting …
Create Layouts by Frames
Topoplan module » Create Layouts by Frames
Create Layouts by Frames Ribbon: Topoplan –Design of Layouts > Creating Layouts by Frames Menu: Topoplan – Design of Layouts > Creating Layouts by Frames Command line: CreateViewFrameLayout The command creates layouts for designing a drawing according to…
Angular dimensions
Execution of Drawings commands » Dimensioning » Angular dimensions
Angular dimensions Ribbon: Home, Annotate – Dimensions > Angular Menu: Dimensions – Angle dimension Toolbar: Utilities – Command line: MDIMANG To draw the angle between two segments: Start the Auto command. Place the cursor over one of the…
Special keys
Construction Module » Basic_know » Special keys
Special keys Key SHIFT Key Shift used: Holding down the SHIFT key is used when placing a dimension value. To place a dimension value closer to any extension dimension line, move the mouse pointer while holding down the SHIFT key. To complete the command,…
Copy layout without viewport
The Component Layout and Plot Drawing » Work with Layouts » To create a layout from a template » Copy layout without viewport
Copy layout without viewport Ribbon: Layout – Layouts > Copy Clean Layout Context menu: Copy clean layout Command line: LAYOUTCLEANCOPY The command allows you to copy all the content and parameters of layout with the exception of viewports. By default,…
Modular Program Configuration
Version 23 » Modular Program Configuration
Modular Program Configuration In addition to the main functionality, nanoCAD includes several independently licensed built-in modules: The Construction module. The module allows you to quickly and accurately draw up design documentation in accordance with the…
Blocks in the sheet set
Sheet Set » Blocks in the Sheet Sets » Blocks in the sheet set
Blocks in the sheet set Connect sheets of sheet set via callout blocks and view label blocks in the drawings. Names of blocks and files with definitions can be input in the Sheet Set tab of the sheet set properties dialog.
Create a rectangular viewport
The Component Layout and Plot Drawing » Viewports » Create a rectangular viewport
Create a rectangular viewport Ribbon: Layout – Layout Viewports > Add Rectangle Viewport Menu: View – Viewports > Rectangular Menu: Insert – Viewports in Layout > Rectangular Toolbar: Layout – Command line: ADDRECTANGLEVIEWPORT nanoCAD allows…
The Calculator
Construction Module » Utilits » The Calculator
The Calculator The calculator is designed for complex mathematical calculations. The capabilities of the table and text editor are significantly expanded using the powerful functionality of the calculator. The calculator is available in the table editor, text editor,…
Create a viewport by object
The Component Layout and Plot Drawing » Create a polygonal viewport » Create a viewport by object
Create a viewport by object Ribbon: Layout – Layout Viewports > Add Viewport by Object Menu: View – ViewPorts > by Objects Menu: Insert – ViewPorts in Layout > By Objects Toolbar: Layout – Command line: DDOBJECTVIEWPORT This command allows you…
Pixel drawing
Working with raster images » Raster drawing » Pixel drawing
Pixel drawing Tools for pixel drawing used for drawing and erasing rater data of an image. To draw on raster image: Ribbon: Raster – Draw > Pencil Menu: Raster – Pencil Toolbar: Raster – Command line: PENCIL Options: Color …
Construction Module » Formats » Use the links in the templates
Use the links in the templates Stamps in the format template Custom format may contain links to templates stamps available in the library. To add a stamp in the format used by the relevant rules. Stamp Position and orientation when you insert a drawing format will be…
Construction text
Construction Module » texts » Construction text
Construction text Main menu: Construction – Text > Construction text. Ribbon: Construction – Symbols > Construction text. Toolbar: Text > Construction text. Command line: SPDTEXT. Dialog An expanded view of the dialog box with text…
Interface Expression Editor
Construction Module » The tables » Interface Expression Editor
Interface Expression Editor The Formula Editor (Expression Builder) allows you to set parameters, arithmetic expressions, and object property references for a selected table cell. The formula editor is invoked: By clicking on the “fx” button in the…
Construction Module » dbscript » Function – event handlers, activated by the base of the application
Function – event handlers, activated by the base of the application Function Comment ActHeader Description of the…
Save changes?
Messages » Save changes?
Save changes? (Query) Text was changed. Select Yes to save changes, No to exit without saving, or Cancel to continue editing. To complete typing the multiline text, press the key combination CTRL + ENTER or click OK in the Text format dialog box. You can also click…
Create a polygonal viewport Ribbon: Layout – Layout Viewports > Add Polygonal Viewport Menu: View – ViewPorts > Polygonal Menu: Insert – ViewPorts in Layout > Polygonal Toolbar: Layout – Command line: ADDPOLYGONVIEWPORT nanoCAD allows use of this…
Big radius dimensioning
Execution of Drawings commands » Dimensioning » Big radius dimensioning
Big radius dimensioning Ribbon: Home, Annotate – Dimensions > Jogged Menu: Dimensions – Big radius Toolbar: Utilities – Command line: DIMJOGGED, DJO The big radius command creates jogged dimensions for circles and arcs. To draw the big…
Creating and editing complex objects » Blocks » Block » Synchronizing attributes of block references
Synchronizing attributes of block references Ribbon: Home – Block > Synchronize Attributes Panel: Edit 2 – Command line: ATTSYNC Updates block references taking into account new and modified attributes from the specified block definition. The command…
Precision tools » Precision tools » Snap and Grid mode » Controlling grid options from the command line
Controlling grid options from the command line Command line: TGRID The command specifies the grid options. Command prompts: Specify grid spacing(X) or [ON/OFF/Snap/Major/ aDaptive/Limits/Follow/Aspect] Specifies the grid spacing. When the spacing value is given…
Model check
Construction Module » BIM » Model check
Model check Functional panel: Model check. Functional panel: Model check report. This tool allows you to check your drawing for errors and non-compliance with standards. The “Model check” functional panel allows you to check IFC models, primitives…
Universal marker
Construction Module » Marker » Universal marker
Universal marker Main menu: Construction – Library objects – Marks and groups > Add marker. Ribbon: Construction – Library objects > Add marker. Toolbar: “Library objects”> Add marker. Command line: SPCREATEUMARKER. The…
Construction Module » dbscript » Object – centre holes GOST 14034-74
Object – centre holes GOST 14034-74 Example of object Source graphic Table SVersion = 2; // The first line of the script determines the version of the interpreter // Description. It will be displayed in the Properties pane // You can also sort the objects in…
Layers Dialog Box
Objects’ Properties » Layers Dialog Box
Layers Dialog Box
Panel HB
Construction Module » dbscript » Panel HB
Panel HB Script of the detail: SVersion = 2; ObjectDescription = @ MCS_STRING6; function ActHeader { NPart = 1; Public ( // Options- exterior length and width of the plate L,LENGTH, W,WIDTH, // Design load and weight plates P, @…
Arrays for arc trajectory
Construction Module » Utilits » Arrays for arc trajectory
Arrays for arc trajectory Tab Arc enter the governing parameters. Follow The selection object (object selection). Select Center array. Follow Preview . Click OK to complete the command. At the top of the window is a control group accommodation, which lets you…
Dimension editing
Execution of Drawings commands » Dimensions editing » Dimension editing
Dimension editing The Edit dimension dialog box (if Yes is chosen for the Dimensions option of the Settings nanoCAD Int dialog box on the Main options tab of the Editing – By double-click section (the Tools menu –Advanced Settings)) can be opened: by…
Expression builder
Execution of Drawings commands » Tables » Expression builder
Expression builder Expression builder interface With expression builder you can specify parameters, arithmetic expressions and references to object properties for the selected cell. You can open expression builder for a table cell and for the Attach object dialog…
Vector Correction
Version 25 » Vector Correction
Vector Correction nanoCAD button – Utilities > Vector Correction Menu: File – Utilities > Vector Correction Command line: AUTOVC The command allows you to correct geometric deviations made during construction or as a result of…
Adaptive note
Construction Module » Note » Adaptive note
Adaptive note nanoCAD Construction allows you to use “Fields (Fields) drawing”. 1. In the context menu of the callout input field, select the “Insert field…” command. The “Field” dialog will open. 2. In the dialog box,…
Removing speckle
Working with raster images » Monochrome filtering » Removing speckle
Removing speckle Ribbon: Raster– Filters> Speckle Remover Menu: Raster – Filters > Speckle Remover… Command line: SPECKLEREMOVER This functionality is available only in the Raster module. The filter removes raster objects (isolated…
Filling holes
Working with raster images » Monochrome filtering » Filling holes
Filling “holes” Ribbon: Raster– Filters> Hole Remover Menu: Raster – Filters > Hole Remover… Command line: HOLEREMOVER This functionality is available only in the Raster module. The filter fills small holes in raster objects. In this…
Basic knowledge
Mechanica Module » Basic knowledge
About the program nanoCAD Mechanica 23 – it is an integrating software solution for platforms nanoCAD, designed to speed up and simplify the design of components, the development, design and editing of design documentation, project data management, focused on the…
Save Objects to a File
Working with raster images » Create new image and rasterize objects » Save Objects to a File
Save Objects to a File Ribbon: Raster – File > Save as Image Menu: Raster > Save Objects to a File Toolbar: Raster – Command line: RASTEROUT The command exports part of drawing to graphic format. After start you will see prompt with a list of selectable…
Edit dimension
Construction Module » mDimension » Edit dimension
Edit dimension LMB double click on the dimension. Context menu: Properties – when calling any dimension. Context menu: Edit – at the selected dimension. Command line: SPFEDIT, FEDIT. The dialog box looks like this: The window is divided…
Snap and Grid mode
Snap and Grid mode Menu: Tools – Drafting settings… > Snap and Grid tab Status bar: and Hotkeys: F9 and F7 Command line: DDRMODES, DSETTINGS, SE Grid is an ordered sequence of points, which with SNAP mode allows specifying restrictions of the cursor…
MechWizard
Mechanica Module » MechWizard
MechWizard implements the following features: · Creating a custom library of parts. · Description of rules of conduct parts in the assembly. · Assignment of output parameters to specify details. MechWizard supports two types of iParts:…
Shape
Execution of Drawings commands » Shape
Shape Ribbon: Home – Draw > Shape Menu: Draw – Shape… Command line: SHAPE Shapes represent the objects described in a special format and are saved in text files with SHP extensions. Shapes can be part of the description of complex line types (for…
Mechanical note
Execution of Drawings commands » Notes » Mechanical note
Mechanical note Ribbon: Home, Annotate – Leaders – Mechanical notes Menu: Draw – Notes > Mechanical notes… Toolbar: Utilities – Command line: NOTE This command opens the Mechanical note dialog box to set the mechanical note options: …
Execution of Drawings commands » Notes » Note for multilayered constructions
Note for multilayered constructions Ribbon: Home, Annotate – Leaders > Multilayered construction note Menu: Draw – Notes > Notes for multilayered designs … Toolbar: Utilities – Command line: NOTEM This command opens the Note for multilayered…
Engineering Analysis
Mechanica Module » Engineering Analysis
Calculation wizard CAD drafting ENGINEERING ANALYSIS 0Main menu: Mechanical – Design – Calculations – CAD software ENGINEERING ANALYSIS 1Calculations wizard. CAD drawing ENGINEERING ANALYSIS 2Ribbon: Mechanical – Design – CAD drafting…
Work with Texts
Execution of Drawings commands » Work with Text » Work with Texts
Work with Texts The text you add to your drawings conveys a variety of information. It may be a complex specification, title block information, a label, or even part of the drawing. In nanoCAD you can create and edit single-line text and multi-line text. For short…
new 14
Construction Module » FormEdit » new 14
new 14 Switch .Switches to monitor the status on/off. Several individual switches interconnected to form a “group switch” to track more states. Example of use of the group switch. Description: Several switches are associated with the same variable…
Gradient symbol
Construction Module » Denote » Gradient symbol
Gradient symbol Main menu: Construction – Symbols > Gradient symbol. * Ribbon*: Construction – Symbols > Gradient symbol. Toolbar: Symbols > Gradient symbol. Command line: SPGRAD. Procedure 1. Call the command. 2. Using the…
The Notes
Construction Module » Decor_params » The Notes
The Notes Settings of notes, such as text, arrows, pointers. Invert oblique arrow Allows you to choose the direction of oblique arrow in leader. Show dialog before inserting the object When this option is enabled, the dialogue is displayed before inserting…
Drawing Design
Mechanica Module » Drawing Design
Drawing borders Working with standard formats CAD drafting DRAWING DESIGN 0Main menu: Mechanica – Drawing title/borders – CAD software DRAWING DESIGN 1Drawing title/borders. CAD drawing DRAWING DESIGN 2Toolbar: CAD drafting DRAWING DESIGN 3Drawing…
Command Line
nanoCAD User Interface » Command Line
Command Line The command line is used to enter commands from the keyboard, to show tooltips and nanoCAD messages, to select the options of the selected command: An accidentally closed command line will appear again after calling any command. If this did not happen,…
Construction Module » Axis » Orientation mark for construction line
Orientation mark for construction line Main menu: Construction – Coordinate axes – Orientation Mark for Construction Axis. Ribbon: Construction – Architecture – Orientation Mark for Construction Axis. Toolbar: Orientation Mark for…
Designing
Design fasteners Threaded fastening CAD drafting DESIGNING 0Main menu: Mechanical – Design – CAD software DESIGNING 1Threaded fastening. CAD drawing DESIGNING 2Ribbon: Mechanical – Design – CAD drafting DESIGNING 3Threaded fastening. CAD…
Section note
Execution of Drawings commands » Notes » Section note
Section note Ribbon: Home, Annotate – Leaders > Section note Menu: Draw – Notes > Section notes … Toolbar: Utilities – Command line: NOTES This command opens the Section note dialog box to set the note options: Options: Use the icons to select the…
Node note
Execution of Drawings commands » Notes » Node note
Node note Ribbon: Home, Annotate – Leaders > Node note Menu: Draw – Notes > Node notes … Toolbar: Utilities – Command line: NLD, NLEADER, NOTEK This command opens the Node note dialog box to set the note options: Options: Use the icons to select…
Linear aligned note
Execution of Drawings commands » Notes » Linear aligned note
Linear aligned note Ribbon: Home, Annotate – Leaders > Linear Aligned note Menu: Draw – Notes > Linear aligned note… Toolbar: Utilities – Command line: LINM This command opens the Linear aligned note dialog box to set the note options: …
Technical conditions
Construction Module » texts » Technical conditions
Technical conditions Main menu: Construction – Text > Technical conditions. Ribbon: Construction – Symbols > Technical conditions. Toolbar: “Text” > Technical conditions. CAD drafting Technical conditions 6Command line: SPTT. A…
ScriptMaster CAD drafting MechWizard 0Main menu: Construction – Library objects – MechWizard – CAD software MechWizard 1ScriptMaster. CAD drawing MechWizard 2Ribbon: Construction – MechWizard – CAD drafting MechWizard 3ScriptMaster. CAD…
Form Editor
Construction Module » FormEdit » Form Editor
Form Editor Database objects nanoCAD Construction supports the use of custom dialogs for inserting and editing. Creating such dialogues (forms) is made in Form Editor, which can be accessed from the dialog boxes Create Group, Create marker and Object Wizard . Button…
Execution of Drawings commands » Work with Text » Editing the content of the text objects
Editing the content of the text objects Ribbon: Annotate – Text > Edit Texts Menu: Modify – Object > Text > Edit Toolbar: Modify Object – Toolbar: Text – Command line: DDEDIT, ED You can also start the Edit command from the context menu…
To create a new layout
The Component Layout and Plot Drawing » Work with Layouts » To create a new layout
To create a new layout Ribbon: Layout – Layouts > Add Layout Menu: Insert – Layout > New Layout Layouts Manager dialog: Create new layout Command line: ADDLAYOUT At the command prompt – Input layout name , enter the name of the new layout and…
Similar construction line
Construction Module » Axis » Similar construction line
Similar construction line Main menu: Construction – Coordinate axes – Similar to Construction Axis. Ribbon: Construction – Architecture – Similar to Construction Axis. Toolbar: Similar to Construction Axis ( “Coordinate…
Chain note
Execution of Drawings commands » Notes » Chain note
Chain note Ribbon: Home, Annotate – Leaders > Chain note Menu: Draw – Notes > Chain notes… Toolbar: Utilities – Command line: NOTEH The command opens the Chain note dialog box to set the note options: Options: Use the icons to select the style of…
Notebook
Construction Module » Utilits » Notebook
Notebook Button Notebook To enter recurring standard text expressions (abbreviations, symbols, etc.) used tool Notebook. This is a versatile tool for some editing tools nanoCAD Construction , which is necessary to enter text. Notebook combines the functions of:…
Display modes
Graphic Display Management » Display modes
Display modes View is a combination of the size, position and orientation of a drawing fragment on the screen. There are different tools and methods allowing you to orient in the document when you edit it. You can zoom or pan the working area for visual control of…
Position
Construction Module » Denote » Position
Position Main menu: Construction – Symbols – Position. Toolbar: Position (toolbar “Symbols”). Command line: SPPOS. Specify the insertion point to the first marker position or call the context menu command…
Construction note
Execution of Drawings commands » Notes » Construction note
Construction note Ribbon: Home, Annotate – Leaders > Construction note Menu: Draw – Notes > Construction notes… Toolbar: Utilities – Command line: NOTEP This command opens the Construction note dialog box to set the note options: …
Construction Module » FormEdit » Interaction of the form with the script
Interaction of the form with the script The form and the design elements located on it interact with the script using properties and events. Properties All form properties start with a prefix “Form.” Control properties (design elements) start with a…
Notepad
Execution of Drawings commands » Notepad
Notepad Button: Notepad The Notepad button is available in the Value picker dialog box and in the Table edit toolbar. Notepad is used to enter temporarily used text (acronyms, symbols etc.). It is a universal tool for text input. Notepad permits: The saving of a…
