Add the selected
Command line: SPADDCOPY.
The command allows you to create a new object nanoCAD Construction based on the type and general properties of the selected object nanoCAD Construction .
1. Call the command “Add selected” – ADDCOPY.
2. Press the “Space” key (the option will turn on) if you want to insert the object in a cyclic mode.
3. Select an object to serve as a template. The paste command for the selected object type will run. The properties of the new object will match the template object.
