Interface. Search Field
Search Field
In dialogs and toolbars, the Search field in the upper right part is intended for quick searching of objects by name. For example, LAYERS, LAYERSQUICK, COVERINGBROWSER:
To replace a part of a word, use the special symbol * (asterisk). For example:
· vie – to display objects starting with “vie”;
· vie – to display objects ending with “vie”;
· ie – to display objects with “ie” in the middle;
· vi*w – to display objects starting with “vi” and ending with “w”.
You can also use the following special symbols in the field:
Symbol Matching characters in name
? Question mark Any single character
  • # Hash sign*
Any single figure.
@ Commercial at Any single letter.
  • Dot*
Any single character other than a letter or a figure.
~ Tilde Any sequence of characters other than the one after the tilde.
  • [ ] Square brackets*
Any single character from those inside the brackets.
  • [~] Tilde in square brackets*
Any single character other than those inside the brackets.
  • [-] Dash in square brackets*
Any single character from the range starting with the character to the left of the dash and ending with the character to the right of the dash.
` Backtick A backtick indicates that the character following it is a regular character and not a special character.
The CAD drawing Interface. Search Field 2 Clear field button resets the search results.
