The Load map underlay
Ribbon: Insert – Maps > Load Underlay
Ribbon: Topoplan – Maps > Load Underlay
Menu: Topoplan – Maps > Load Underlay
Command line: REMAPVIEW
The command allows you to load back the underlay content after unloading it by the Unload Underlay command. Only the outline is displayed for the unloaded underlay.
The command works identically to the Map State underlay parameter on the Properties bar.
