Arc construction axis
Main menu: Construction – Coordinate axes – Separate arc construction Axis.
Ribbon: Construction – Architecture – Separate arc construction Axis.
Toolbar: Separate arc construction Axis ( “Coordinate axes”).
Command line: SPARCCLINE.
To create a separate arc axis
Specify center point of the axis.
  • Specify radius of arc (click or enter a value on the keyboard).
  • Specify the start angle (click or enter a value on the keyboard).
  • Specify end angle (click or enter a value on the keyboard).
The double-click to open the context menu arc axis.
Column Marker name contains a list of the names of the markers. To add a new marker, click in an empty field and enter the name of the marker.
Options arc axis:
  • Hide marker – hides the marker so it is only displayed in the drawing axis;
  • Move marker – moves marker to the other end of the shaft;
  • Two side marker – adds a marker at the other end of the axis;
  • Hide axis – the axis hides, only the marker;
