Purging of document
This command is used to purge unused named elements from a document: block descriptions, dimension styles, layers, text styles and line types.
Using this procedure, you can reduce file size after finishing your project.
ATTENTION! Deleted elements cannot be recovered.
The Purge dialog box appears after the command is launched. There is a list of elements which available for deletion, and a list of elements which are not available for deletion. The list is organized as a tree: to open a list of elements of one type, click twice on the elements name or select the sign to the left of the name. If there is no sign, it means that there are no elements of this type to delete (or which cannot be deleted).
Parameters:
View elements you can purge
View elements you cannot purge
Confirm each item to be purged
Purge nested items
Purge zero-length geometry and
empty text objects
Automatically purge orphaned
data
Buttons:
To delete elements with confirmation:
1. Switch on the Confirm each item to be purged mode.
2. Select the !https://manula.r.sizr.io/large/user/13178/img/purging-of-document-s-3.png or
3. In the opened dialog box confirm purging of the elements:
Buttons:
Purging a document using the command line
Full
All
Enter type of unused objects to purge [Blocks/DEtailviewstyles/Dimstyles/Groups/Layers/LTypes/MAterials/MUltileaderstyles/Plotstyles/SHapes/textSTyles/Mlinestyles/SEctionviewstyles/Tablestyles/Visualstyles/Regapps/Zero-length_geometry/Empty_text_objects/Orphaned_data/ANnotscales/Point_clouds/Full/All]:
Enter name(s) to purge <*>:
