This topic deals with the actions committed in the Sheet Set Manager over sheet sets, sheets, sheet sunsets, sheet selections, views, view categories and invoked from the context menus or from the supplementary dialogs.
Activate opened sheet set
The Sheet List tab, root node context menu: Active Sheet Set – click on sheet set name
Close active sheet set
The Sheet List tab, root node context menu: Close Sheet Set
Refresh active sheet set
The Sheet List tab, root node context menu: Refresh
Resave all sheets of active sheet set
The Sheet List tab, root node context menu: Resave All Sheets
Batch plot active sheet set
The Sheet List tab, root node context menu: Publish
Create new sheet in the sheet set
The Sheet List tab, root (subset, sheet) node context menu: New Sheet…
Import layout as a sheet
The Sheet List tab, root (subset, sheet) node context menu: Import Layout as Sheet…
Remove sheet from the sheet set
The Sheet List tab, sheet node context menu: Remove sheet
Change sheet name and number
The Sheet List tab, sheet node context menu: Rename Renumber…
Create new sheet subset
The Sheet List tab, root (subset) node context menu: New Subset…
Rename selected subset
The Sheet List tab, subset node context menu: Rename Subset
Remove selected subset
The Sheet List tab, subset node context menu: Remove Subset
Create new sheet selection (option 1)
Select sheets and subsets in the sheet set tree.
The Sheet List tab:
– Create…
Create new sheet selection (option 2)
The Sheet Selection Set Manager dialog: New
Check sheets to be included into selection.
Rename sheet selection
The Sheet Selections Manager dialog: Rename
Delete sheet selection
The Sheet Selections Manager dialog: Delete
Set View by categories mode
The Sheet Views tab:
– View by Category
Set View by sheets mode
– View by Sheet
Create new view category
The Sheet Views tab: the View by Category mode – root node context menu – New View Category…
Rename view category
The Sheet Views tab: the View by Category mode – view category node context menu – Rename…
Delete view category
The Sheet Views tab: the View by Category mode – view category node context menu – Remove
Edit view category properties
The Sheet Views tab: the View by Category mode – view category node context menu – Properties
Set existing category to a view
The Sheet Views tab: the View by Sheet mode – view node context menu– Set category
Insert view to sheet
The Model Views tab: view node context menu – Place on Sheet
Change view name and number
The Sheet Views tab: view node context menu – Rename Renumber
Import named views
The Sheet List tab, root node context menu: Import Named View as Sheet…
The Sheet List tab, subset node context menu: Import Named View as Sheet …
Use Browse for Drawings… and Use current drawing buttons to select files for import named views to the active sheet.
Insert view callout block
The Sheet Views tab: view node context menu – Place Callout Block
Insert view label block
The Sheet Views tab: view node context menu – Place ViewLabel block
Add new model views location
The Model Views tab: root node context menu – Add New Location…
