The command converts a set of 3D Face or SubMesh type objects to one or several Polyface mesh type objects.
Apply changes? Yes – conversion will be performed with the current settings.
or [Yes/No]: No – if the settings have been changed, they will not be preserved. Conversion will be performed with the settings that displayed right after the command started.
| Split meshes by topology | A method of exploding a mesh into smaller meshes: · Yes – split a mesh into parts taking into account both topology (Maximum difference of normals in mesh option), and limitations (no more than 32767 faces and vertices). · No – split only on the basis of limitations (no more than 32767 faces and vertices). |
| Maximum difference of normals in mesh (degrees) | The maximum allowable deviation of the normal of a mesh element from its average normal (in degrees), at which the element will be considered to belong to this mesh. The normals of elements in each part, into which a single mesh will be split, should not differ by more than a given value. The option determines the number of pieces into which the mesh will be split, if the Split meshes by topology option is set to Yes. |
| Vertex tolerance | Accuracy parameter within which closely located nodes (vertices) of objects will be combined during conversion. For example, the vertices of neighboring faces may not match within 1e-0.4, but with the Vertex tolerance value equal to 1e-0.2 such vertices will be merged into one. |
