SVersion=2;
The first line of the script, which determines the version of the interpreter
strTheType
Object type
strTheName
Object Name
strTheSubType
Subtype object
pntOrigin
Insertion point
vecDirection
Vector insertion direction
VecPlane
Orthogonal vector to vecDirection
Scl
Object Zoom
rZOrder
Ranking (used for overlap)
strDesignName
Execution system name
rXcoord
Relative abscissa cursor with dynamic selection of the parameters
rYcoord
Relative ordinate cursor with dynamic selection of the parameters
VecCoord
Mostly available in OnSelectParam
VecCoord: X – X coordinate of the relative
VecCoord: Y – Y coordinate of the relative
pntGrip#
(# Number) point pens with the number #
rPart
Serial number of the request.
rKbd
Flag keyboard input. Equal to 1 if the value is entered from the keyboard.
strPartName
Name of detail in the specification (section name)
strPartDescription
Part description in the specification (section designation)
strPromt
Help line (in the dynamic selection or when selecting items for a connection)
NSelect
The number of requests when inserting objects.
NPart
Number of selectable parameters if 0 or undefined then simply called dialogue.
BreakCur
End the current dynamic parameter selection
BreakAll
Complete the entire cycle of selection of dynamic parameters
NoVectorSelect
Does not indicate the vector inserts (used at a connection)
Handled
Result processing facility
NGrip
Number of Handles
NMovingGrip
Phone editable pens
lSimpleView
Variable specifies the type of species, UniDialog created and installed automatically.
If == 1 – a simplified view.
If == 2 – sectional view
scaleDisable
If this parameter is set to 1 in UniDialog prohibits the changing Scale
ShowWhenSelPnt
If this box is checked, the object will be drawn at the time of insertion, if not specified, it is enabled by default
ContourOnLine
Generation circuit is not drawing from a script, and on the fly after drawing
IsAHole
The object is a hole (Embedded object)
OnDlgBeforeSelectParam
Call dialogue before calling OnSelectParam.
IsACalculator
Is set equal to 1 for the calculations
No3dViews
Disables automatic views
AutoShift
Automatic pseudo-pressing of the Shift button
UseOnlyZOrder
Used only for crossing rZOrder, do not use Z-coordinate
fUseCommonScale
Maintain external control scale
MINPOSSIBLEVALUE
The minimum acceptable value for the application
NotStdBody
If == 1, then the item is placed in the component catalog
SpecPartition
Unit specifications, which gets the item
