Add View
Main menu: Construction – Library objects > Add view.
Ribbon: Construction – Library objects > Add view.
Toolbar: Add view (on toolbar “Library objects”).
Context menu: Add view (on select object).
Command line: SPADDVIEW.
Designed to quickly add a new type of projection from the base of the inserted object to the drawing.
  • Select the object to copy.
  • Specify the insertion point of the object. Context menu commands Front / left / right / top / bottom standard projection (to insert a particular projection, it is necessary that it be recognized in the object).
  • Context menu commands Point, Angle mode selection switch, respectively the insertion point or selection mode direction.
  • Complete the cyclic command.
    Adding a projection view to the object database can be done using the Add View from the context menu for the selected object.
