Arc length dimension
Main menu: Dimensions > Arc.
Ribbon: Annotate – Dimensions > Arc length.
Ribbon: – Symbols > Arc length dimension.
Toolbar: Dimensions > Arc length.
Context menu: arC – when calling any dimension.
Command line: SPMDIMARC, MDIMARC.
Arc dimension
To apply the dimension you need:
1. Select the arc dimension;
2. Select an arc (the arc dimension will snap to the arc);
3. Specify the insertion point.
Circle dimension
2. Specify the starting point on the circle;
3. Specify the end point on the circle;
4. Specify the insertion point.
