The Edit Command
The command allows you to edit nanoCAD’s objects such as tables, notes, dimensions, singleline and multiline text.
The command opens following dialogs for editing:
- a table, a note, a dimension, a singleline and a multiline text (the Text settings dialog window) – if Yes is chosen for Program objects, Dimensions, Regular text and Multi-texts options of the Settings nanoCAD Int dialog box on the Main options tab of the By double-click section (the Tools menu –Advanced Settings),
- a table, a note, a dimension – if No is chosen for the Program objects and Dimensions options of the Settings nanoCAD Int dialog box on the Main options tab of the By double-click section.
For more information, see the corresponding sections of this guide.
Info: NanoCAD is a simple, affordable, and yet professional, CAD platform for personal computer, that delivers a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our program supports creative, collaborative and customizable features to raise your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
