Axes array
Settings of construction axes array. It allows you to change the location of the construction axes, place symbols, color, size and style of text and lines.
Store grid options
When this option is enabled, each following array of axes will use the parameters of the previous.
Explode an array
When this option is enabled, array created will be split to individual axes.
