Match layer
The command moves selected objects to another layer. It is possible to select objects beforehand.
| Name | Opens the Change to Layer dialog for selection of destination layer from the list. |
| Select an object to change its layer or [?]: | Select objects. |
| Select object on destination layer or [?/Name]: | Select objects on a layer, where you want to move objects to. |
| Select object on destination layer or [?/Name]: | Select the Name option to specify a destination layer in the Change to Layer dialog. |
Selection of commands to work with layers in the dialogs
The dialogs open when you select the Name option and shows list of layers, which you can select as a destination layer or layers for merging or removal.
- In the command prompt Select object on destination layer or [?/Name]: select Name.
- Select a layer from the list in the dialog.
- Press OK.
To create a new layer:
- Enter a layer’s name in the dialog field.
- Press OK.
- Accept a layer’s creation.
Multiple selections are acceptable when you merge or delete layers in the dialogs.
With the SHIFT button pressed all layers are selected from the first to the last click.
With the CTRL button pressed you can add any layer from a list to a selection.
Info: NanoCAD is an easy-to-use, inexpensive, and yet powerful, CAD software tool for PC, that allows a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our software ensures creative, collaborative and customizable features to boost your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and buy later, if you like it.
