Break and Restore dimensions
If necessary, you can use breaks to improve the readability of the graphical information and exclude errors in the dimensions on the drawing. The Break dimension command, unlike the Explode command from the Modify menu, does not break the completeness of the dimension and does not result in a loss of the association with the object.
Essentially, the Break dimension command does not remove the dimension part, but places a mask on it.
To break the dimension (or rather, to place the mask), it is necessary to select two points on the dimension or extension line that define the location and length of the mask.
When you edit the dimension or an object that intersects dimension, the dimension mask (break) will not be updated automatically. So after moving the dimension or editing an object that intersects dimension, you should first restore the dimension and then add a dimension mask (break) again.
Dimension Break
Creates a break in the dimension. When you create a break, turn on the Nearest snap (or switch on the To turn the object snap “Nearest” on automatically during an insert of objects option in the nanoCAD – Options dialog box on the Main tab of the Edit section (the Tools menu – Settings parameters).
Option:
| Unbreak | Removes the breaks in the selected dimension. |
| Select dimension to break or [?]: | Select the dimension. |
| Select first point [Unbreak]: | Select the first point. |
| Select second point [Unbreak]: | Select the second point. |
When you select a dimension, the Break line command will be available from context menu.
Dimension Restore
Removes the dimension breaks created by the Break dimension command.
The following prompt is displayed:
| Select dimensions to unbreak or [?]: | Select the dimensions and press ENTER. |
When you select dimension, the Unbreak lines command will be available from the context menu.
Explode dimensions
In some cases, it is necessary to explode a dimension into separate parts – lines, arrows, arcs and dimension text. To perform this operation, use the Explode command from the Modify menu.
It is strongly recommended not to explode the dimensions unless there is a specific need.
Info: NanoCAD is an easy-to-use, low cost, and yet powerful, CAD program for PC, that allows an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our program provides groundbreaking, collaborative and customizable features to raise your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD app development. You may try nanoCad for free, using the links below, and purchase later, if you like it.
