Appendix 3. Object Classes
For some types of objects in the database has its own class reserved:
| Number |
Icon |
Description |
| 200 |
Default object. By default, when creating a new object, class 200 is assigned. The developer can assign his own class to created objects. All classes of objects, except for the ones described below, will have the same icon. |
| 600 |
Blueprints. All object classes from 600 to 650, except for the ones described below, will have the same icon. |
| 601 |
Tables, specifications |
| 630 |
System object |
| 631 |
Collection |
| 632 |
Object project construction site |
| 633 |
Object – building site signs |
| 634 |
Master of Engineering |
| 646 |
Bolted, riveted connections |
| 645 |
Batch file, when clicked, the command stored in the comment is sent |
| 647 |
Callouts |
| 648 |
Markers |
| 649 |
Templates |
| 650 |
Object groups |
| 670 |
Window |
| 671 |
Wall |
| 672 |
Wall modifier |
| 673 |
Wall object |
| 674 |
Architecture object |
| 675 |
Column |
| 676 |
Opening |
| 680 |
Door |
| 750 |
Piles |
| 751 |
Additional crane objects |
| 752 |
Load chart |
| 806 |
Formats |
| 807 |
Stamps |
| 809 |
Cover Sheet and Cover Templates |
| 820 |
Connectors |
| 821 |
Track |
| 822 |
Equipment with connectors |
