Similar object
Main menu: Construction -Architecture – Graphics > Similar object.
Ribbon: Construction – Architecture > Similar object.
Command line: SPSIMILAROBJECT.
The command is used to create parallel lines, concentric arcs and circles.
1. Call the “Similar object” command.
2. Specify the object on the drawing for which you want to create a similar one.
3. Specify the position of the new object.
