Compound objects
This command is used to overlay preset assembly and parametric dependencies on objects in the drawing.
After running the command must specify.
Child object – an object that will be joining.
Parent object – the object to which you will attach the child object.
Upon completion of the command will be imposed on the details of parametric and geometric constraints defined in their script..
