Geometric constructions
Tools nanoCAD Construction for the geometric constructions are specific for mechanical design. All objects created with their help, made up of primitives nanoCAD, and does not require special tools for editing.
Editing inserted objects in a drawing can be performed using a universal object editor nanoCAD Construction , called button “Editing”. After selecting the object being edited is automatically recognized by the type and loads the appropriate dialog box.
Furthermore, editing objects nanoCAD Construction it can be made by other means:
called the command “Edit” in the context menu;
by calling the “Edit” command from the tooltip of the selected object. This method is set in the “Editing” section of the design settings nanoCAD Construction ;
double-clicking the LMB on the object nanoCAD Construction . This method is set in the “Editing” section of the design settings nanoCAD Construction ;
use grips of object;
on the function panel “Properties”;
standard command ERASE, MOVE, COPY, ROTATE, STRETCH.
