Layer off
Turning the layers of selected objects off. It makes these objects invisible both in model and paper spaces.
The commands allows to freeze layers of selected objects only in a current viewport (if Viewports = Vpfreeze parameter is selected).
| Settings | Starts other options to select objects. Switches to the selection parameters mode. Selected parameters are saved for the next session. The option starts the following prompt in the command line: Enter setting type for [Viewports]:
In paper space viewport use [Vpfreeze/Off] :
| Undone | Cancels selection of previous layer to be turned off (or frozen in a current viewport). |
Command prompts when layers are turned off:
| Select an object on the layer to be turned off or [?/Settings]: | Select objects of the layers which is needed to be turned off. |
| Select an object on the layer to be turned off or [?/Settings/Undone]: | Select Undone option to cancel turning the previous layer off. |
| Select an object on the layer to be turned off or [?/Settings/Undone]: | Press ENTER or ESC to finish the command. |
NOTE: Command prompts are shown for Off option of Viewports parameter.
Command prompts when layers are turned off in a current viewport:
| Select an object on the layer to be turned off or [?/Settings]: | Select Settings option. |
| Enter setting type for [Viewports]: | Select Viewports option. |
| In paper space viewport use [Vpfreeze/Off] : | Select Vpfreeze option. |
| Select an object on the layer to be turned off or [?/Settings]: | In a viewport select objects of the layers which are needed to be turned off. |
Command prompts when layers are turned off in the block selection:
| Select an object on the layer to be turned off or [?/Settings]: | Select the Settings option. |
| Enter setting type for [Viewports/Block selection]: | Select the Block selection option. |
| Enter Block Selection nesting level [Block/Entity/None/] | Select the option for the nesting level. |
| Select an object on the layer to be turned off or [?/Settings]: | Specify in the drawing the objects of the layers to be turned off. |
| Select an object on the layer to be turned off or [?/Settings/Undone]: | Press ENTER or ESC to complete the command. |
Info: NanoCAD is a simple, cheap, and yet professional, CAD application for PC, that provides an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our freeware provides groundbreaking, collaborative and customizable features to boost your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD app development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
