Export to LandXML
The command exports a surface (Mesh object) to the LandXML format for use in other applications.
After running the command, select a surface to be exported to the XML file. The command options will be displayed on the Properties toolbar:
| Xml units | Displays the units in which XML file will be saved. |
| Geodetic CS | As in the geodetic coordinate systems (as opposed to the generally accepted rectangular Cartesian) the X axis is directed to the north, and the Y axis – to the East, for the correct export of object to XML file, it is required to specify the parameter value – Yes. If you specify No, X and Y coordinates will reverse places during import. |
| _.Surface | Enables/disables export of surface (SubMesh object). |
| _.Geopoints | Enables/disables export of geopoints. When exporting, the belonging of points to a group remains. |
Info: NanoCAD is a simple, cheap, and yet powerful, CAD freeware tool for personal computer, that provides a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our program supports creative, collaborative and customizable features to raise your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD app development. You may try nanoCad for free, using the links below, and buy later, if you like it.
