Calculting surface area
The command is designed to define the area of a surface patch. The objects for calculation are Submesh or Polyface mesh.
Apply changes or [Yes/No]:- Yes – the area will be calculated with the current settings.
- No – if the settings have been changed, they are not saved. The area will be calculated with the settings, that were displayed immediately after running the command.
Specify closed contour
Specify a surface patch in a drawing. It is the most convenient to specify contour in visual styles with filling.
To end, press Enter.
The result will be displayed in the command line. The total area, area in the projection to XY plane, area in the projection to XZ plane, area in the projection to YZ plane will be calculated. The values of areas are given in the drawing units.
Info: NanoCAD is a simple, affordable, and yet professional, CAD platform for personal computer, that allows an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our tool supports creative, collaborative and customizable features to enhance your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and buy later, in case you like it.
