List of openings
Command to generate a list of all allocated openings in the drawing.
After running the command you need to select the insertion point of the table.
Then select the openings included in the statement. To do this, select a region (rectangle) all necessary doorways.
Important! In order to correctly fill the list of openings the openings on the drawing must have different positions.
