Calculating surface volume
The command allows to calculate volume of surface or surface area.
| Volume |
| Define contour |
| Create Mtext label in drawing |
Apply changes or [Yes/No]:
- Yes – the volume will be calculated with the current settings.
- No – if the settings have been changed, they are not saved. The volume will be calculated with the settings, that were displayed immediately after running the command.
Info: NanoCAD is a simple, low cost, and yet professional, CAD platform for Windows, that delivers an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our software supports progressive, collaborative and customizable features to raise your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and buy later, in case you like it.
