Using styles
Style assignment to table cells is performed by the command CAD drafting Using styles 0“Select cell style” in the toolbar of the table editor or tab “Fit” in dialogue “Cell properties”. he choice of style is carried out in the graphics window. Also, styles can be created and edited using the context menu.
Context menu
- Apply – the command applies the selected style on the cell (group of cells).
- Update – the command replaces the selected style with the style of the selected cell.
- Rename – command allows you to rename the name of the style. The name of the style is generated automatically during creation.
- Delete – command removes the selected style from the list.
- Import – command imports style in * .mcd format.
- Export – command exports the style in * .mcd format.
- Create – command allows you to create a new style.
Creation order:
1. Set the cell style.
2. Open the style window
3. Select the “Create” context menu command.
4. A new style will be created. The name of the style is generated automatically during creation.
