Custom settings files are located in the folder:
%APPDATA%\Roaming\Nanosoft AS\nanoCAD x64 25\NanoSPDS\en-US\AllOptions.xml
To transfer the settings, you need to copy these files to the appropriate folders, and in the settings nanoCAD Construction then specify the path to the design element settings.
Important!
The function of saving the settings, when the saved file is the same as the one already existing, does not overwrite the old file, but complements it. I.e., when changing the standard, for example, from the ESKD to ISO, both standards will be available in the settings file.
All changes to the profile table must be saved to the configuration file, otherwise these changes will only be displayed in the current work session.
