NRX and LISP file loading
The command allows you to load NSF, MultiCAD API, LISP, .NET and NRX-applications to nanoCAD.
After starting the command the Load/Upload Applications dialog box appears:
To load a file, select it in the top of the dialog box and click the Load button. All files loaded in this nanoCAD session display in the list of the Loaded applications tab.
To record the history of the loading, select the Add to history checkbox. The list of previously loaded files can be viewed on the History list tab.
It is possible to automatically load the applications when you start nanoCAD. To do this, click the Contents button in the opened dialog box and add the files that should be automatically loaded for each new nanoCAD session.
After loading of the NSF, NRX, MultiCAD, .NET or LISP application, its commands, that can be started from the nanoCAD’s command line, are available.
NOTE: Unlike AutoCAD, where a LISP-application is loaded only into the current document, the commands of LISP-applications loaded in nanoCAD are available during whole working session from any documents.
Info: NanoCAD is a simple, cheap, and yet professional, CAD freeware tool for Windows, that allows an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our program provides innovative, collaborative and customizable features to enhance your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD application development. You may download nanoCad for free, using the links below, and purchase later, if you like it.
