Editing tables on the drawing
The on-screen table editor is opened by starting the In-place edit (ipedit) command or left-clicking the table frame while holding down the CTRL key.
To enter the content of a cell:
- Place the cursor above the cell.
- Left-click.
The active cell is then highlighted in green. The text entered in a cell is automatically condensed to fit the cell width.
The Table Edit toolbar is shown when a table is being edited on-screen.
Buttons:
Group cells | Use this button to merge adjacent cells:
Ungroup cells | Use this button to restore previously merged cells into single cells:
Split cells | This button divides a cell into smaller cells:
Pencil | Use this button to split a cell into multiple cells by drawing additional cell borders:
Add row | Adds a row to the bottom of the table. |
Add column | Adds a column to the end of the table. |
Insert row | Adds a row to the table at the cursor position. |
Insert column | Adds a column to the table at the cursor position. |
Delete row | Deletes the row containing the active cell. |
Delete column | Deletes the column containing the active cell. |
Row properties | Use to alter the height of the row containing the active cell. A dialog box appears in which the row height, in millimetres, can be specified: ![]() |
Column properties: | Use to alter the width of the column containing the active cell. A dialog box appears in which the column width, in millimetres, can be specified: ![]() |
Cell properties: | Opens the Cell Properties dialog box. Use this to set the properties of the selected cell. |
Cells properties: | Use this to set the properties of multiple cells:
Sum: | Use these buttons to automatically add up the values from the selected cells and display the sum in a blank cell at the end of the selection. When using these functions, do not enter any sum |
Selective sum: | expressions in the Cell Properties dialog box. |
Notepad: | Opens the Notepad dialog box. |
Calculator: | Opens the Calculator dialog box. |
Special symbols: | This button allows a special symbol to be inserted from the menu. |
Exit: | Exits the on-screen table editor. |
Info: NanoCAD is a user friendly, affordable, and yet powerful, CAD platform for Windows, that provides an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our freeware supports innovative, collaborative and customizable features to improve your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and purchase later, if you like it.
