You can specify a background mask for multiline text, for multiline multileader text and for multiline block attribute text. A background mask allows text to appear on an opaque background of a specified size and color.
A mask is created for the entire text area. When you resize the text area using grips, the mask (background) is also resized.
To create a background mask:
1. Select the multiline text, multiline multileader text or multiline block attribute text.
2. on the Properties panel, click the
Or select the Background Mask item in the context menu, while editing multiline text (or multileader multiline text, or attribute multiline text):
In the dialog that opens, configure the parameters.
| Use Background Mask | Whether or not to hide the background of multiline text. |
| Background Offset | The size of the mask margins around the text area. The coefficient value is tied to the height of the text. If the coefficient value is 1, then the size of the mask corresponds to the size of the text area. With a value of 1.5, the background extends out of the text area by a distance equal to half the height of the text. Cannot be less than 1. Below is the result for values 1 and 2.8. ![]() |
| Fill color | Mask color. Use the current background color or set your own. |
Info: NanoCAD is a simple, cheap, and yet professional, CAD platform for PC, that delivers an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our freeware provides creative, collaborative and customizable features to boost your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and buy later, if you like it.
