DecorTable
Settings of the tables in nanoCAD Construction .
Layer
Specifies layer for placing tables.
Color
Sets color of table elements.
Line thickness
Allows you to choose the thickness of the lines of text in the table.
Option “by layer” sets the line width from the layer it is placed (default value).
Option “By block” sets the line width for by the block in which it is included.
Option “By object” sets the line width individually using properties palette.
Selecting “Default” sets the default line thickness for the table.
You can also set the line width of a standard set of values.
Text style
Sets the default text style in the table
Text Height
Allows you to choose the standard text height.
Text Color
Control choice of color of text in tables.
Text weight
Width factor
Sets width factor for text in table cells.
Text Indent
Sets text indent in table cells.
