Classification mesh
The command is used to divide the mesh into classes: for example, if you want to separate the road surface from the lawn. For classification, in the drawing it is necessary to create polylines (necessarily closed), along which the mesh will be cut. After the mesh is classified, the resulting areas can be decomposed into layers to control the display (you can adjust the visibility, color, transparency, etc.)
The command options are set on the Properties toolbar.
| Project profile on | Determines how the polyline cutting the mesh will be projected on it:
| Save result as | The option influences on objects to be created in the process of performing the command: a Submesh or Polyfacemesh can be created. |
