Standards Check Options
NOTE: The
Dialog box for setting standards check.
Notification settings
(system variable STANDARDSVIOLATION)
Disable standards notifications
Display alert upon standards violation
Display standards status bar icon
Check standards by the command
Save, Save as, Import, Plot, eTransmit
Check options
Automatically fix nonstandard properties
In this case, the properties of the standard object are assigned to the nonstandard object. After the check is completed the number of automatically fixed violations is displayed in the alert box.
Show ignored problems
Preferred to use for replacement
- If there is a recommended replacement (flagged in the Replace with list), then this recommended replacement is selected by default regardless of a file selected in this field.
- If no recommended replacement is found, and a standards file (DWS) is selected, the first replacement of the selected standards file is chosen.
- If None is selected for this option and a recommended replacement is absent, nothing is selected for replacement.
Info: NanoCAD is a simple, cheap, and yet professional, CAD app for personal computer, that delivers an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our freeware provides progressive, collaborative and customizable features to improve your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD application development. You may download nanoCad for free, using the links below, and buy later, if you like it.
