Changing the transparency of raster images background on the screen
The command allows you to switch the transparency of the background pixels of bitonal raster images (for example, TIF format), as well as the alpha channel pixels of color images (for example, PNG format).
NOTE: The command switches the transparency of raster images background only on the screen. Raster images are not modified.
To change the transparency of raster image background:
1. Run the command.
2. Select the required option: Enter transparency mode [ON/OFF] :
The background transparency of selected raster images can also be changed in the Properties bar.
Info: NanoCAD is an easy-to-use, low cost, and yet professional, CAD freeware tool for personal computer, that allows an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our program provides progressive, collaborative and customizable features to improve your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and purchase later, if you like it.
