nanoCAD integration
nanoCAD Construction integrated into nanoCAD as modules.
Default file opening setting
By double-clicking on the drawing file (or by using the “Open” command from the context menu), the nanoCAD platform is loaded without loading the nanoCAD Construction .
Windows 8 and above
In order for the nanoCAD Construction module to load, it is necessary:
1. Open the application selection menu: RMB on the *.dwg file. – Open with – Select another application.
2. Select applications to open and check the box “Always use this application to open .dwg files”.
3. Ready.
Windows 7
In order for the module nanoCAD Construction to load, you must:
1. Launch nanoCAD.
2. Open settings.
Main menu: Tools – Options….
Ribbon: Manage – Castomization – Options.
3. In the settings window, open the “Current profile” drop-down list.
4. Select “SPDS”. Along with the choice of profile, the mode of operation of the platform will also change. In the settings tree: Application preferences – Licensing – Modules – Platform mode.
5. Click the “OK” button.
6. Restart nanoCAD to change settings.
7. Setting completed. Files will now open with the nanoCAD Construction .
