Work with LISP-applications
After starting the command, select the necessary option in the command line.
| COmmands Functions Variables |
Outputs the commands, LISP variables and loaded LISP-applications to the command line. |
| Load | Allows to load LISP-file with lsp or mnl extension by entering whole path of the file and its extension. |
| Execute | Allows to execute one of the functions lsp or mnl file, that was loaded by using the Load option. |
| Console | Converts nanoCAD command line to the LISP console mode. In this case, the command prompt changes to _>:![]() In the nanoCAD, entered function can be performed in the Console mode. To exit the LISP-console mode, enter (quit) or (exit). |
Info: NanoCAD is an easy-to-use, cheap, and yet professional, CAD app for Windows, that allows an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our software provides innovative, collaborative and customizable features to raise your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and buy later, if you like it.
