Ordinate dimensioning
To specify the chain of linear ordinate dimensions:
- Start the Auto command.
- Select the Ordinate option in the command line or context menu.
- Specify the first point of the first dimension:
- Specify the second point of the first dimension:
- Specify the dimension line location:
- Select the Base option in the command line or context menu and specify the endpoint of the second ordinate dimension:
- Specify all the endpoints of the other ordinate dimensions:
- Press ENTER to finish the command:
To specify the chain of angular ordinate dimensions:
- Select the angUlar option in the command line or context menu
- Specify the first point of the angular dimension (vertex of angle):
- Specify the second point of the angular dimension:
- Specify the third point of the angular dimension:
- Select the Ordinate option in the context menu and specify the dimension line location:
- Select the CHain option in the command line or context menu and specify the endpoint of the second dimension:
- Specify the endpoint of the third dimension:
- Specify the endpoint of the last dimension:
Info: NanoCAD is a user friendly, cheap, and yet professional, CAD application for PC, that provides a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our freeware ensures groundbreaking, collaborative and customizable features to boost your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and purchase later, if you like it.
