Object Snap tracking mode
Parameters:
Object Snap Tracking On (F11) Switches object snap tracking mode on/off.
Object Snap Tracking modes
Track to alignment point Switches on/off the display of tracking lines to an object’s characteristic points.
Clear track points on “shift + mouse wheel” Switches on/off the erasing mode of the snap point marker on a tracking line using SHIFT and the mouse wheel.
The context menu of the OTRACK button:
Parameters:
Track using polar angles Switches using object tracking together with polar tracking mode on/off. In this case, the tracking lines for all angles specified in the Polar Tracking tab in the Drafting Settings dialog box are displayed.
Track ortho only Switches the display of tracking lines only in ortho directions on/off.
Don’t track polar Switches off polar tracking mode.
Track to any alignment point Switches on/off the display of tracking lines to specific points.
Clear track points on SHIFT + mouse wheel Switches on/off the erasing mode for the snap point marker on a tracking line.
On/Off Switches object tracking mode on/off.
To use object tracking mode:
1. Switch on the OTRACK and OSNAP modes in the status bar.
2. Use the cursor to capture the required characteristic objects’ points to set tracking lines. Place the cursor near a point to capture it. A captured point is marked with + symbol. To deactivate a point already captured, move the cursor over it again.
3. Dotted tracking lines, going through one or several captured points and the cursor’s pick box, will appear when you move the cursor within the drawing. You can snap to points on those lines or to the intersection points. The more types of object snap that are switched on, the more points will be available for capture.
To zoom and pan, the + marker is removed from captured points.
Example: Circle in the center of a rectangle.
1. Defining the center of rectangle:
2. Specifying the circle center:
3. Specifying the circle radius:
Info: NanoCAD is a user friendly, inexpensive, and yet powerful, CAD app for personal computer, that delivers an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our program supports groundbreaking, collaborative and customizable features to enhance your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and buy later, if you like it.
