Linear dimensions
Main menu: Dimensions > Aligned.
Ribbon: Annotate – Dimensions > Aligned.
Toolbar: Dimensions > Aligned.
Context menu: aLigned – when calling any dimension.
Command line: SPMDIMALI, MDIMALI.
Horizontal dimension
Context menu: Horizontal – when calling any dimension.
Command line: SPMDIMHOR, MDIMHOR.
Vertical dimension
Context menu: Vertical – when calling any dimension.
Command line: SPMDIMVER, MDIMVER.
Parallel, horizontal, vertical dimensions
To apply dimensions, you must:
1. Choose dimension;
2. Select the type of binding:
“nEarest snap gets object” – dimensions the entire selected object;
“nEarest snap gets point” (default) – sets dimension nodes at a selected location on an object.
3. Specify the end nodes of the dimension based on the selected snap type:
“nEarest snap gets object” – specify an object, the end nodes of the dimension will be the end points of the object;
“nEarest snap gets point” – specify the start and end nodes on the selected object.
4. Place the dimension number. The dimension will be built.
Auxiliary markers
Construction markers appear when you select a certain linear dimension:
Parallel dimension is selected.
Horizontal dimension is selected.
Vertical dimension is selected.
Linear dimension
Main menu: Dimensions >6Linear.
Ribbon: Annotate – Dimensions >Linear.
Toolbar: Dimensions >Linear.
Command line: DIMLINEAR.
Linear dimensioning
1. Call the “Linear” command;
2. Specify the first node;
3. Indicate the second node;
4. Place the dimension number. Linear dimension will be created.
