The command creates new geopoints at the nodes of surface faces. Geopoints take X, Y, Z coordinates from surface nodes. The geopoint style is assigned by default (Standard).
| Select objects or [?]: | Select a surface in the drawing field. |
The command line will display the number of points created.
The command has no options.
