Polar Tracking mode
Drafting settings… > Polar tracking tab
Polar tracking mode helps to specify a point, set at a specified distance and angle from the last selected point. The dotted tracking line with a tooltip shows the distance from the last specified point and current angle value.
Using polar tracking mode, you can create geometric creations with any specified interval. For example, if an angle of 30 was selected, tracking lines will be displayed when the direction from this point to the cursor’s pick box is a multiple 30° (e.g. 60°, 90°, 120° and so on).
Specify the increment of the polar angle in the Polar tracking tab of the Drafting Setting dialog box or from the context menu of the POLAR button.
Parameters:
Polar tracking on (F10) Switches polar tracking mode on/off.
Polar Angle Settings
Increment angle: Specifies the increment angles used for polar tracking lines.
Additional angles: Switches on/off the mode for specifying any additional angles (which do not depend on the increment angle)
Object Snap Tracking Settings
Track orthogonal only: In OSNAP mode tracking lines are only drawn horizontally and vertically.
Track using all polar angle settings: Switches on the mode for applying the parameters of polar tracking to object tracking. In this mode the cursor is moved from the point of object snap using aligning angles.
Do not track Polar: Switches off the polar angles tracking mode.
To specify additional angles:
1. Enter an angle value,
2. Select the Add button.
To delete an additional angle:
1. Select the angle in the section,
2. Select the Delete button.
The context menu of the POLAR button contains the available increment angles:
Parameters:
Set custom angle: Specifies a new angle of polar snap direction in the command line.
On/Off: Switches the polar angles tracking mode on/off.
Info: NanoCAD is a simple, inexpensive, and yet powerful, CAD platform for personal computer, that delivers a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our program provides groundbreaking, collaborative and customizable features to boost your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD application development. You may download nanoCad for free, using the links below, and purchase later, in case you like it.
