Accelerators Tab
Accelerators tab allows you to add keyboard shortcuts (hot keys) combinations for often used commands
Keyboard shortcut – is a combination of symbol key and control keys CTRL, SHIFT, ALT, For example, press CTRL+O to open a file, ; CTRL+S – to save the document, etc.
To create a shortcut
1. Click Create accelerator button.
2. Press the desired combination on a keyboard.
If combination is already used, the field is highlighted.
3. Pres the button
4. Select the desired command in a Select command dialog box.
It is possible to set accelerators from context menu of the commands list.
Additional accelerator for command
1. Select the command in the list of shortcuts.
2. Call the Find tool context menu.
3. Select command in the list and call Create accelerator context menu.
4. Press the desired combination on a keyboard, then click OK
Change accelerator
1. Select command in the list of shortcuts.
2. Set new combination in Properties.
Remove keyboard shortcut
1. Select command in the shortcut list.
2. Click Delete accelerator button.
Info: NanoCAD is a simple, low cost, and yet professional, CAD application for Windows, that delivers a great user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our freeware supports progressive, collaborative and customizable features to improve your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD application development. You may download nanoCad for free, using the links below, and purchase later, if you like it.
