Main menu: Dimensions >
Break dimension.
Main menu: Construction – Breaks >
Break dimension line.
Ribbon: Annotate – Dimensions –
Ribbon: Construction – Symbols >
Toolbar: Dimensions >
Toolbar: Construction Breaks>
Command line: SPDIMBREAK, DIMBREAK.
To create a dimension line break, you must:
- Call the command;
- Select the dimension. If the size was selected before calling the command, you do not need to select it again;
- Select two points by specifying a section of the dimension line to create a break;
First point selection
Second point selection
Result
Restore dimension line
Restore dimension.
Unbreak dimension line.
Ribbon: Unnotate – Dimensions >
Command line: SPDIMUNBREAK, DIMUNBREAK.
To restore the dimension line, you must:
- Call the command;
- Select the dimension. If the size was selected before calling the command, you do not need to select it again;;
- The restoration will be done.
