Moving a vertex
The command moves a point in an existing surface (Submesh or Polyface mesh) and rebuilds the triangulation. The movement takes place in the XY plane.
To move a point:
- Run the command.
- In response to the prompt in the command line
Select vertex to move
select a vertex. When you hover the cursor over the mesh node that will be selected for moving, it is highlighted in red. - After specifying the node, the prompt follows:
Pick new vertex position
It is possible to specify a new position of vertices with a snap to the objects of situation.
The node position has been changed
- Several vertices can be moved in succession. Pressing ESC button ends the command.
Info: NanoCAD is a user friendly, affordable, and yet professional, CAD software tool for Windows, that delivers an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our software ensures progressive, collaborative and customizable features to improve your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and purchase later, in case you like it.
