Insert point
Main menu: Construction – Library objects – MechWizard > Insert point.
Ribbon: Construction – MechWizard > Insert point.
Toolbar: Insert point ( “MechWizard”).
Command line: SPWIZINS.
The insertion point should always be shown on the sketch of the parametric model. Click to choose its position on the sketch.
If you try to check the model or recognize the form of a sketch in which the insertion point is not specified on the command line, you are prompted to “Select insert point”. Then you need to specify the sketch position of the insertion point.
In the case of several insertion points in the sketch, recognition will be considered only of the one that has been specified later, and all others will be ignored.
