Group Edit
Main menu: Construction – Edit > Group edit.
Ribbon: Construction – Utilities - Group edit.
Toolbar: Group edit ( “Edit”).
Command line: SPEDITGROUPS.
The command allows you to edit bolted or riveted connections.
  • Click on the button Group edit;
  • Select any item in the drawing either a bolted or riveted joint;
In the window that opens, make the necessary changes.
Furthermore, editing group nanoCAD Construction – objects can be produced by double-clicking the left mouse button on the axis of the assembly.
