The command creates new geopoints by interpolation between two points specified in the drawing.
| Specify the first point or [Settings]: | Specify the first point of the distance. |
| Specify the second point or [Settings]: | Specify the second point of the distance. |
| Specify points count <1> or [Settings]: [Settings]: |
| Apply changes [Yes/No/save/saveDefault] : | Yes – the command will be performed taking into account the settings changes made by the user in the current command session. No – the command will be performed with the settings that were displayed immediately after the command was launched. save – saving settings to the document. saveDefault – saving settings to the register. |
Labels of new geopoints are obtained by interpolation between the specified ones. Several points can be added sequentially. Press the ESC button to end the command.
