Every time you select the Save As command, nanoCAD will offer to specify a path to the file and/or change the file name in the Save Document File dialog. The selected path and entered file name are set by default, and when the Save command is used, the file will be saved with the path and name specified earlier.
NOTE: Navigation pane in the nanoCAD list displays only those folders that are specified in Common files location section of the Options dialog.
To save the document with another name:
- Select folder to save the file.
- Change the name in File name field.
- Select the desired file format in Save as type list.
- Click the Save button.
The Save As command can be used to change the format of a file, specified to save all documents using Save, Save As and WBLOCK.
Info: NanoCAD is a user friendly, low cost, and yet professional, CAD software tool for Windows, that delivers an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our software supports progressive, collaborative and customizable features to boost your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and buy later, if you like it.
