Create a rectangular viewport
nanoCAD allows use of this command on the current layout tab in which the viewport should be located, as well as directly from the model space.
Create a rectangular viewport from the model space
When you create a viewport from the model space, specify, with a frame, the drawing area (in the model space) that should be displayed in the viewport.
| Specify viewport first corner: | Specify the first corner of the rectangular viewport in the model space |
| Specify the first corner of the rectangular viewport in the model space | Specify the opposite corner of the rectangular viewport in the model space Select the name of layout in Select Layout dialog to insert a viewport and press OK button. Active before running of command layout is highlighted in the layout list. |
| Input or choose view scale <1.000000>: | Input the viewport scale. |
| Specify Viewport Center Point: | Specify the viewport center point. |
Create a rectangular viewport from a layout
| _.Extent | Display all objects from the model space in the viewport |
| Active<0.000831> | Display the current view of the model space in the viewport. |
| Paper<1.000000> | Set the viewport scale corresponding to the layout scale. |
| Specify viewport first corner: | Specify the first corner of the rectangular viewport in the layout tab. |
| Specify viewport second corner: | Specify the opposite corner of the rectangular viewport in the layout tab. |
| Input or choose view scale or [Extents/Active<0.000831>/Paper<1.000000>]: | Input the viewport scale or select the required option. |
Info: NanoCAD is a simple, affordable, and yet powerful, CAD freeware tool for personal computer, that delivers an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our program provides innovative, collaborative and customizable features to boost your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and buy later, in case you like it.
