Justify Text
Changes the justification point of a text object without moving the text.
NOTE: Changing the type of alignment without changing the position of the text or the text area in the drawing is performed by the ……….. Justify Text (JUSTIFYTEXT) command.
The command is useful when you want to alter the position of the Insert object snap (INSertion) for text objects without moving the text.
1. Select text object.
2. Start the Justify Text (TJUST) command.
3. Select the desired type of justifying in the command line or context menu.
| Start | Justify text by the left margin. |
| Center | Justify text by the horizontal center. |
| Middle | Justify text by the horizontal and vertical center. |
| Right | Justify text by the right margin. |
| TL | Justify text by the top and left margins. ![]() |
| TC | Justify text by the top margin and horizontal center. ![]() |
| TR | Justify text by the top and right margins. ![]() |
| ML | Justify text by the left margin and vertical center. ![]() |
| MC | Justify text by the vertical center and middle of horizontal. ![]() |
| MR | Justify text by the right margin and vertical center. ![]() |
| BL | Justify text by the bottom and left margins. ![]() |
| BC | Justify text by the bottom margin and horizontal center. ![]() |
| BR | Justify text by the bottom and right margins. ![]() |
Info: NanoCAD is a user friendly, low cost, and yet professional, CAD app for personal computer, that provides an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our program ensures innovative, collaborative and customizable features to enhance your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD application development. You may download nanoCad for free, using the links below, and purchase later, in case you like it.
