Drawing regeneration
Sometimes, when you are working with a document after the command is finished, some visual elements stay on the drawing; for example, markers of characteristic points. To delete such visual elements, use forced regeneration (specified manually) or redrawing of a drawing.
Two commands in nanoCAD are used for it: Regen and Redraw (View menu).
Redrawing a drawing is faster than regeneration because all the drawing objects’ coordinates are recalculated (converting values with floating points from the drawing database to integer display coordinates) during regeneration.
Regeneration
The Regen command is used for a forced update of a current drawing.
Command performs following actions:
- Recomputes the locations and visibility for all objects
- Recalculates tables
- Updates automatically calculated attribute values.
Redrawing
The Redraw command is used for a forced update of a display.
Info: NanoCAD is a user friendly, inexpensive, and yet powerful, CAD freeware tool for PC, that allows an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our freeware ensures progressive, collaborative and customizable features to boost your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD app development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
